The driveshaft, and suspension has 109k miles on it.
Driveshaft $90 shipped, $50 picked up. OBO
Front suspension is from a '97 318ti with sports package. Sits nice and low. Brakes are cross drilled zimmerman rotors, with PBR or APD, or something like that for pads. Steering thing works properly. Asking $460 picked up. no ship.
Your profile says "DASC Trunk Impaired Vibrator". That wouldn't be because of the driveshaft, would it?
Seriously though, I wonder if it would fit my '95. I don't have that giant ring on the end of the shaft. Just the rubber guibo.
A member once had 3400lb vibrator for his avatar (mitsubitshi 3000gt).
so... my car has been deemed "trunk impaired", so I added a vibrator title to it.
I don't see why it wouldn't fit a '95. Check under your car where the selector rod is. If the selector rod is bent, then it will MOST likely fit.
DO IT
No the selector rod isn't bent. When I installed an M3 shift lever I noticed that.
Does that giant ring come off? Will it still bolt to a guibo? How are the u-joints, nice and loose?
I'll check into it tomorrow, too dark right now.Originally Posted by ClubSportCohort
